Thin wall model _Fidap_membrane
Old   May 22, 2002, 04:42
Default Thin wall model _Fidap_membrane
George
Hello everybody
I have created and meshed a geometry of a human artery in Gambit and I want to analyze the stresses and displacements of the wall. I want to solve it with the thin wall theory in Fidap 8.6.2. The only boundary conditions I use is the pressure (BCFLUX), which is 16000 Nt/m2 (similar in inlet and outlet). Can you help me how can I proceed? Thank you in advance
George
Old   May 27, 2002, 02:44
Default Re: Thin wall model _Fidap_membrane
jwt
I have a question: How do you add the pressure boundary conditions on the inlet and oulet of pipe? Can you give me the command text about the above? Thank you very much!
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 08:18
Quenching simulation - wall boiling model Michael.J CFX 10 August 27, 2013 18:02
UDF for wall slipping HFLUENT Fluent UDF and Scheme Programming 0 April 27, 2011 13:03
3-D turbulence model with wall function Henry Main CFD Forum 7 May 19, 2006 11:40
Standard wall function vs Two layer model C. ORTEGA FLUENT 0 July 7, 2003 09:35
