STill not working :(
Old   May 15, 2002, 16:24
Default STill not working :(
Jonathan
hi, i have an axial flow fan based in a cylinder. Setting the BC for the axial fan as an absolute rotational moving wall with rotational axis perpendicular to the supposing flow : X axis=1 (which the out flow is Z axis).Then i declared the fluid's rotation axis as X=1 with rotational speed of 2000rpm. One quick question here is why the fluent tutorials (tut 17 fluent 5) declare the fluid as the rotational factor (2000rpm) instead of the fan which is the one turning at 2000rpm. BC for the inlet and outlet are set as pressure inlet and pressure outlet respectively where the outlet has the radial setting ticked and bot inlet and outlet having set to "direction vector" where Z is the component of flow direction.
Now with all these settings, the velocity magnitude does'nt give the required arrows showing the flow thru the cylinder, instead just rotational flow around the fan. Please highlight me where have i gone wrong as i have been trying much different settings for the past few days without much success. Best Regards
Old   May 22, 2002, 04:48
Default Re: STill not working :(
moiami
I'm STill puzzling over it too as I have similar difficulties although my problem description isn't the same as yours.
You can read up more about it in Fluent 5 User's Guide Vol 3 Chap 16 and Vol1 in Section 6.13.1 and if you can solve that problem of yours pls tell me how you do it, okay.
Old   May 22, 2002, 15:15
Jonathan
i managed to get it to run after much trial and error, what i did was to label the fluid as a staionary object not as a moving reference frame as the tutorial has suggested. The fan was declared as a moving wall. try decreasing the relaxation factors say to 0.3 to 0.5, and with u having a good mesh, it shld work. oh my inlet was declared as pressure inlet and outlet as pressure outlet with Radial eq. Changed my continuity from 1 to 1e-05. i'm using k-e btw
Old   May 23, 2002, 00:11
moiami
Good fer ya. I tried so many trial & errors to get mine to work including doing the one u said. My system is a stirred tank. When I spec the fluid as stationary and move the impeller (moving wall w speed rel. to adj cell) I got a lot of stagnant region which shouldn't be here. I'm still trying though, by varying a lot of the BCs input.
DPM parallel is not working but serial is working johnwinter FLUENT 1 March 27, 2012 03:01
Working Principle of Micro-Oven aero Siemens 2 January 31, 2007 06:00
Help required on working of Micro-oven aero CFX 4 January 19, 2007 09:21
Help required on working of Woven aero FLUENT 0 January 16, 2007 07:25
Need a working supersonic-calculation Gernot FLUENT 1 March 18, 2006 09:51
