non-positive volume
Old   May 7, 2002, 07:54
Default non-positive volume
Emilien
I have a problem of :"non-positive volume" when I want to iterate. what does it mean? (I work with a 2d model!)
Old   May 8, 2002, 00:55
Default Re: non-positive volume
Jin-Wook LEE
You may have meshing problem. Check youe DBS file by GAMBIT.
Sincerely, Jinwook
Old   May 8, 2002, 05:18
Erwin
I have seen this problem occur most times with pretty skewed meshes that have been smoothed in Gambit.
Old   May 8, 2002, 18:31
Sundar
1. The first step as soon as export your mesh in to Fluent is to do a grid check. 2. If you have a no positive volume. (In your case for a 2d problem, its non positive area.) 3. Grid check indicates u have a non positive area. 4. All this indicates is you don't have a quality mesh and your mesh contains inverted elements. 5. Get back to Gambit land or your preprocessor land and try obtaining a decent mesh. 6. For a 2d problem this should be trivially simple.
Sundar
Old   May 9, 2002, 06:03
Emilien
thank you very much for your answers
Actually, I use a moving mesh model, and I have noticed that for the 1st mesh, it is ok, but when I start the iterations for the unsteady problem, I have this problem of non-positive volume (confirmed by the grid check)
Can anyone help me about these problems of non-positive volumes with moving meshes?
Old   May 15, 2002, 16:11
JiChun
There is a limitation of using deforming mesh in FLUENT. It can't solve the problem with too large deformed meshes. Otherwise your mesh skewness will exceed the tolerance of the FLUENT. The only way is to rebuild your deformed meshes to minimize the mesh skewness.
Old   May 16, 2002, 03:43
Markus
I guess your problem connected to the requirement that the interfaces between zones moving relatively to each other have to be completely indepentend. In other words, even no single vertex must be shared by both interfaces. (use DISCONNECT VERTICES in GAMBIT)
Yours sincerely, Markus
Old   December 14, 2010, 13:15
roger
roger_pn is on a distinguished road
Originally Posted by Emilien
;100797
I'm trying to export a 3D mesh to Fluent but it says that i have non-positive volume and that the minimum volume value is negative. What does this mean??
I've tried to smooth all volumes and to check the validity of them and it says all volumes are valid. So i don't know why i have a negative volume. I'm meshing a rear wing of a World series by renault car (simulating the ailerons and the wind tunnel).
Thank u for the help.
roger_pn is offline   Reply With Quote
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
