May 3, 2002, 06:53 |
Templates in Fluent
Hi.
Is it possible to make a template in Fluent, so if I have similar models I can re-use BC's, material data etc. I know that it is possible to read a dpm file, although you have to make the file first, and then import it (it would be nice if Fluent could make a dpm file from the gui). Cheers Christian |
May 5, 2002, 21:43 |
Re: Templates in Fluent
Use 'write-bc' and 'read-bc' from TUI(Text User Interface), not from GUI. Then you can write and read everything in the case file.
Sincerely Jinwook |
May 6, 2002, 03:18 |
Thank you, Jinwook.
Do you know if it is possible to de the same thing with the materials database. When I use DPM, I have to alter the database, and errors may occur. Cheers Christian |
May 6, 2002, 06:09 |
No, the same command works well for the database as well. Just use write-bc and read-bc as Jin-Wook said.
Stopping a Fluent batch job AND saving the data! Possible? | Volker Pawlik | FLUENT | 13 | December 28, 2020 05:16 |
Two questions on Fluent UDF | Steven | Fluent UDF and Scheme Programming | 7 | March 23, 2018 04:22 |
Compared MRFSimpleFoam and Fluent in a centrifugal pump! | renyun0511 | OpenFOAM Running, Solving & CFD | 8 | July 6, 2010 07:24 |
Fluent 12.0 is worst then Fluent 6.2 | herntan | FLUENT | 5 | December 14, 2009 03:57 |
Problems in lauching FLUENT | Lourival | FLUENT | 3 | January 16, 2008 17:48 |
