continue the problem with RSM modeling
Old   April 23, 2002, 23:09
Default continue the problem with RSM modeling
cwflying
Several days ago, I have put forward my question "Problem with RSM modeling" here. Some recommended me to use Pressure-Outlet boundary conditions at the two outlets.
But finally I want to solve a two-phase problem (fluid-particulate separation). When I use pressure-outlet boundary conditions at the two outlets,a "Volume Fraction"(the volume fractions of all secondary phases) will appear, but I could only decided the volume fraction at the inlet (velocity inlet boundary conditions),in terms to the fraction at the two outlets,I do not know.
Another question, when I am attempting "DISCRETE PHASE",even thougt I have created a new
material in "define>materials", I still could not find it in the drop list of "discrete phase>injections>create>materials" panel. I have created the new material(particulate) as
solid or fluid twice,it did not appear in the drop list either.
(PS:my previous question: http://www.cfd-online.com/Forum/fluent.cgi?read=7548)
Old   April 25, 2002, 07:01
Default Re: continue the problem with RSM modeling
cwflying
Any advice is welcome,thanks!
Old   April 25, 2002, 11:46
Jichun
Your question is almost the same as what I asked in the last post. No any fedback yet. In my current simulation, I just set the two outlets as the pressure_outlet boundary with ambient pressure. As for the volumn fraction for the second phase, set them as zero. Actually these values will be updated during your simulation. You can try and see. I only found this result by trying, no any solid reason from the FLUENT manual.
Old   April 28, 2002, 08:48
cwflying
And the question about discrete phase,could you give me some suggestion?Thanks a lot!
Problem in modeling membrane gas separation hakim22 FLUENT 0 July 31, 2011 11:28
problem in modeling thin wedge in cfx m.salemi CFX 1 July 25, 2011 19:49
A problem with solar still modeling Amir Khodabandeh FLUENT 2 April 3, 2011 22:55
problem is modeling and simulation of an air foil alnabhani CFX 4 December 2, 2010 14:24
problem with RSM modeling cwflying FLUENT 4 April 18, 2002 07:45
