problem with RSM modeling
Old   April 17, 2002, 06:21
Default problem with RSM modeling
cwflying
I am carrying out a numerical simulation of a hydrocyclone using FLUENT5.46,RSM modeling.
Firstly,I choose a simple modelne-phase(water),2D,axisymmetric.
As you know,a hydrocyclone has an inlet and two outlets, in "boundary conditions",I define the inlet as "velocity inlet", and the two outlets(overflow and underflow) as "outflow", the problem is: in RSM modeling, you must give a "Flow Rate Weighting" for all outflow boundaries(between 0 and 1), in my simulation the overflow and underflow are not equal, but I do not know the exact fraction of each outflow, so how could I define the "Flow Rate Weighting"?
Any suggestion is urgent! Thanks a lot!
Old   April 17, 2002, 08:25
Default Re: problem with RSM modeling
cfd guy
Have you tried the pressure-outlet condition? In this kind of BC you don't need to specify this weighted flowrate. You only need to specify the gauge pressure distribution and the turbulent parameters.
Regards, cfd guy
Old   April 17, 2002, 14:32
Anindya
Use Pressure Outlet. Do not use outlet.
Old   April 18, 2002, 04:10
kim
use pressure outlet, not outflow
Old   April 18, 2002, 07:45
Jin-Wook LEE
All replying posting is correct. Use pressure outlet rather than outflow. But you should know the static pressure of both outlet. The problem is, in most cases, the static pressure at the two outlet is not the same and fairly difficult to obtain.
Sincerely, Jinwook
Aeroacoustic Problem (Modeling Flow-Induced Noise Problems Using FLUENT) cici Main CFD Forum 0 September 29, 2011 15:28
A problem with solar still modeling Amir Khodabandeh FLUENT 2 April 3, 2011 22:55
The problem of modeling free jet with VOF river FLUENT 0 December 27, 2005 03:29
Filter modeling problem Nishant FLUENT 2 September 15, 2005 13:41
Writing a BCDEFI problem for RSM model S. Bottenheim Siemens 2 January 28, 2005 09:55
