VOF,Multiphase modeling
Old   April 17, 2002, 02:58
Default VOF,Multiphase modeling
Mavinakere
Hi all,I've been recently working on multiphase phase modeling of air and water around a automobile tire.I ran some 3D calculations for the domain 50mm from the ground and 370mm wide.Water is 8mm hegh and rest till top 50mm is air.I used K-E, RNG to get solutions.Well, when i compared my results with the abstract paper i had...the pressure values seems to match but not the force values...i'm getting the lift and drag forces approximately 10 times more than the obtained values in the paper.Can anybody please throw some light on my problem? Thanks in advance.Mavinakere.
May Focus Area: Turbulence Modeling Jonas Larsson CFD-Wiki 0 May 2, 2006 12:48
Modeling Flow/Saturation/Absorption in Fibers Gene Dougherty Main CFD Forum 0 June 6, 2003 15:49
Solid Modeling Chris Main CFD Forum 10 July 2, 2002 08:12
CFD Modeling of Two-phase Flow in Small Dia.Tubes Eric Poindexter Main CFD Forum 2 September 22, 2000 10:21
Extrusion Modeling Elliot Schwartz Main CFD Forum 1 September 11, 1998 20:08
