Too many vertices and faces - GAMBIT
Old   April 12, 2002, 12:29
Default Too many vertices and faces - GAMBIT
Dhananjay
Hello all,
I am trying to create a geometry in GAMBIT that involves subtraction of some cylinders from a rectangular box. I find that this results in the creation of hundreds of new faces. I cannot delete most of these faces because they are connected to 'upper topogical identities'. Is there any way to get rid of them?
Thanks.
Dhananjay
Old   April 12, 2002, 13:24
Default Re: Too many vertices and faces - GAMBIT
An Modh Coinniolach
I take it you are subtracting volumes from volumes. Normally I would have expected that to work well enough in Gambit.
Delete the volumes you are left with, but keep the lower geometry (faces). You can them delete these (or perhaps healing them would be the way to go). Then build up your volume from the faces.
[blockMesh] Internal walls of zero thickness anger OpenFOAM Meshing & Mesh Conversion 23 February 6, 2020 19:25
Gambit meshing error jx FLUENT 11 May 26, 2009 11:35
Gambit error: cannot select faces and volumes smillerhh FLUENT 1 December 15, 2006 10:07
between IDL Gambit and rhino, any help? philip FLUENT 0 June 23, 2005 13:08
Seperate faces from vertices Samir Siemens 0 November 29, 2004 12:16
