April 10, 2002, 22:05 |
postprocessing
Hi all,I'm working with a multiphase model with air and water at certain velocities around a object.I'm getting results 10 times the expected results, though the pressure values are the same what i expected.So,i assume my calculations are correct but the postprocessing is wrong.The lift force and the drag forces are 10 times the expected values..I used K-E model,VOF.Can anybody let me know what could be the possible errors for this calculations.Thanks.Mavinakere.
using fieldAverage library to average postprocessing | eelcovv | OpenFOAM Programming & Development | 32 | May 17, 2022 10:55 |
How to export the specific heat and viscosity for postprocessing (compressible) ? | david39 | OpenFOAM Post-Processing | 2 | January 4, 2019 08:04 |
[pythonFlu] Postprocessing using pythonFlu + Matplotlib +Scipy | francois | OpenFOAM Community Contributions | 2 | June 21, 2011 12:26 |
Question about Postprocessing Using UDF(in tutoria | sarah_ron2002 | FLUENT | 1 | April 10, 2007 17:17 |
postprocessing | bas rijkse | FLUENT | 0 | July 5, 2001 09:30 |
