Hi, all:
After calculating an air flow field, I tried to display the wall shear stress along a wall. The vector display showed clearly that there's a region of negative wall shear (where the flow recirculation occured), but the xy-plot of wall shear showed me all non-negative values. Could anyone tell me why this happened? Is it because that Fluent only gives the magnitude when doing xy plot? Thanks a lot. Ellen |
Hello,everybody.Now I am solving flowfield around airfoil NACA0012,which has attack angle of 4degrees and a Ma number of 0.8.For the first time,I use a C-type grid,the second time,a hydrid one with a rectangular farfield boundery(C-tyep around the airfoil,and triangular ). But the second Cd doubled the first one, whereas there is a little difference between Cl and Cm. Can anybody tell me why?
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 00:04 |
Wall Shear Stress | GamFlu | FLUENT | 0 | June 11, 2011 03:52 |
relationship between wall shear stress and TKE | winter | FLUENT | 0 | December 11, 2007 17:11 |
Re: About wall shear stress | Mike | FLUENT | 9 | November 17, 2003 14:41 |
