incompressible free surface flow past cylinder
Old   March 30, 2002, 05:26
Default incompressible free surface flow past cylinder
vineet
i am a new fluent user.i want to model free surface flow past asemi submerged cylinder in water. i am specifying the free stream velocity at in flow and initial pressure and velocity throughout the mesh. i have done the initial meshing using gambit. can someone explain in what steps do i have to go further for free surface flow solution. thank you.
Old   March 30, 2002, 20:27
Default Re: incompressible free surface flow past cylinder
david
A) Use VOF, [segregated solver (no choice)] B) You have to patch the volume fractions. DC
Old   April 1, 2002, 06:56
vineet birman
what conditions should i take at the outer boundary during gambit, there is pressure inlet given as option. i will specify velocity and pressure both there. At the cylinder i am taking it to be as wall during gambit.
Free surface flow settubg boundary conditions and plotting velocity profiles prashanthreddyh FLUENT 2 October 21, 2015 10:58
Problem with capturing water-spreading for free surface flow devesh.baghel OpenFOAM 2 December 10, 2009 02:21
free surface flow same as FSI??? Ken CFX 1 February 18, 2008 20:43
Free surface vortex flow Guillaume CFX 3 August 25, 2005 21:52
Free surface channel flow in Fluent 6 Tiberiu FLUENT 2 February 6, 2005 04:41
