fluent animation techniques
Old   March 22, 2002, 05:48
Default fluent animation techniques
khalil
looking through the archives i found these instrucions on how to animate an unsteay solution.
1 Set up the view interactively as you want it.
2 Go to File/Hardcopy and set up the output format and size you want (I used tiff and 560x400 pixels)
3 Go to Solve/Monitors/Commands, add one comand to be performed every time-step. In the command field write a text comman which plots and saves what you want. Here is an example: /display contour pressure 0 300000 /display hard-copy ramp_%t.tiff
but when i enter these instructions, fluent doesnt save the tiff files and produces the following message:
vortex_%t.tiff invalid command [vortex_%t.tiff]
any help would be very much appreciated
many thanx
khalil
Old   March 22, 2002, 11:59
Default Re: fluent animation techniques
Erwin
Check your command syntax in the text interface before you use them in the command panel.
I believe the filename should be enclosed by " "
Old   March 22, 2002, 13:04
andy
The file name should be in " ", that is your problem, I do animations for stuff all the time, if you cannot get it work now, drop us a note, and I will write down the exact syntax,
Cheers
Andy
Old   March 22, 2002, 16:15
anna
1. set in display what you want to be displayed. 2. go to file/hardcopy, choose the file format, color etc., and click on "apply". 3. go to solve/execute commands, set the number of commands you want, with the name of the file to be under quotes. You don't need hardcopy of your display every time step or you do? 4. click on "OK"
anna
Parallel fluent not using all processors specified Paul FLUENT 18 October 26, 2023 04:54
Animation Error in Fluent Andrew FLUENT 9 October 1, 2020 17:42
Animation Error in Fluent Andrew Main CFD Forum 0 October 14, 2009 03:25
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 17:48
Fluent Animation FV FLUENT 0 September 6, 2004 10:18
