NEW flow-induced noise module in FLUENT 6??
Old   March 18, 2002, 05:18
Default NEW flow-induced noise module in FLUENT 6??
jon
dear gurus, I have read that the new FLuent 6 has the capability to estimate flow-induced noise propagation/source. Can i stretch the capability to capture the flow-induced noise if I were to set up a simple rotor-stator (sliding mesh)model and in the process solving for the noise flow due to their interaction both in the far/near field?
secondly, if there is a noise-estimation module in version 6, How is the governing equations/algorithm used in capturing the sound source(eg. lighthill analogy?)Does it take into account shock-induced/turbulence noise at blade-tip etc?
thanks a million
Viscoelastic flow modeling in Fluent Ankur Navra FLUENT 3 July 26, 2013 06:56
Compressible flow modeling in Fluent nikhil FLUENT 8 August 9, 2011 15:18
[ASK] Flow in Corrugated Pipe with FLUENT Primadhani FLUENT 1 May 11, 2011 21:41
How do I select solver options for external flow over an aircraft by fluent? hadieliasi FLUENT 5 May 2, 2011 04:54
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
