problem with setting up compiled udf
Old   March 12, 2002, 14:33
Default problem with setting up compiled udf
sivakumar
hi all,
i dont know what does this mean, has anyone come acrsoss this error message? when i try to run the nmake command from the command line in windows-nt, i get the message "nmake is not recognized as an internal or external command, operable program or batch file". can any one plese claarify what does this mean and the solution to this problem. thanks in advance. sivakumar
Old   March 13, 2002, 09:22
Default Re: problem with setting up compiled udf
Christian Schnitzer
hi!
did you follow the instructions in the FLUENT UDF-Manual correctly - means: have you copied the needed files and installed the obligatory directories?
Old   March 13, 2002, 12:24
Default Re: problem with setting up compiled udf:problem s
sivakumar
hi, thanks, it was some installation problem, its solved now. thanks. siva
A problem about 'printf' and 'Message' in UDF. LICH Fluent UDF and Scheme Programming 2 May 2, 2013 03:45
problem with udf for dynamic mesh ja92 FLUENT 0 February 24, 2011 10:32
what's the problem with my udf zzyan FLUENT 0 November 4, 2010 04:56
problem in compiled UDF kumar FLUENT 1 October 5, 2005 19:40
setting up compiled UDF library in windows2000 sivakumar FLUENT 1 October 19, 2001 04:46
