UDF & Accessing Turbulence Properties
Old   March 5, 2002, 14:14
Default UDF & Accessing Turbulence Properties
Dimal
I'm using Fluent 5.5 (awaiting 6.0), and just starting to play around with UDF to create a custom turbulence model (more like simple changes to the current models). I don't seam to have any problem accessing the vel, press, temp, enthalpy variables but I can't seam to even print out (in the a UDF Adjust function) the turb. KE, dissipation, or reynolds stresses.
Can anybody shed some light onto this problem.
Thanks, Dimal
Can Fluent Import New Turbulence Model By UDF? Andy Cong FLUENT 4 March 25, 2016 14:14
Accessing profile data from a UDF ral007 Fluent UDF and Scheme Programming 1 October 14, 2015 10:21
problem with UDF for (v2-f) turbulence model in fluent artemiss1984 Fluent UDF and Scheme Programming 6 January 17, 2014 06:50
Accessing wall shear stress using UDF Robert Fluent UDF and Scheme Programming 2 July 31, 2013 09:34
UDF - accessing face variable problem argeus FLUENT 2 February 9, 2011 05:08
