error while writing bc
Old   March 5, 2002, 08:20
Default error while writing bc
Theju
Hi, I am trying to write out the boundary conditions using file>write-bc filename.bc but I am encountering the error below. can some one help in this regard ---- /file> write-bc sample.bc writing rp variables ... Done.
Error: eval: unbound variable Error Object: downcase
Thanks
Old   March 7, 2002, 15:39
Default Re: error while writing bc
Peter
Are you using profiles or constant values to pescribe BC's?
Old   March 8, 2002, 00:59
Theju
I am using profiles at some boundaries and constant values at the remaining boundaries.
Old   March 8, 2002, 14:20
Peter
I am asking because I got the same error when using profiles to prescribe BC. Could anyone shed some light into this problem?
solid to fluid heattransfer with chtMultiRegionFoam nakor OpenFOAM 11 March 21, 2011 09:28
overflow during writing result adam2008 CFX 2 March 21, 2011 09:11
An error has occurred when Writing backup file tian CFX 0 June 28, 2007 22:29
journal file command for writing mass flow rate James FLUENT 0 July 26, 2006 11:51
Fatal error error writing to tmp No space left on device maka OpenFOAM Installation 2 April 3, 2006 09:48
