Grid Adaption problems
Old   February 25, 2002, 15:41
Default Grid Adaption problems
Jie
hi,
I have a problem of FLuent grid adaption. How to use register to refine grid? I don't how much I can use for refine threshold on the grid adaption panel. However the default value 1 e 10 is too much for any adaption. I want to know how much refine threshold you used for mass imbalance , velocity and pressure correction.
Thanks very much.
Jie
Old   February 26, 2002, 12:03
Default Re: Grid Adaption problems
Erwin
Look at your grid & solution to find what might be off: cell size to big to capture fine flow details, high velocity or pressure gradients, etc etc. Then decide how to adapt: boundary adaption, region, gradient, etc etc. Set the limits in such way that:
1) you capture the problem area. Use the 'Display' option in the 'Manage' panel to see where the marked cells are.
2) you end up with a reasonable amount of cells after adaption.
Repeat process until satisfied.
You can use registers for more complex adaptions: you can select one type of adaption, mark the cells, then select another adaption, mark the cells again, and then the 'Manage' panel allows you to combine them or subtract the registers from one another (by using 'Change Type' before you combine).
Problems in grid generation in ICEM Tim CFX 1 September 30, 2006 07:43
Grid adaption or Gambit meshing? ravi varma FLUENT 8 December 12, 2002 14:09
Adaption by Y+ on a mixed grid with periodics Martin Shanel FLUENT 0 June 24, 2002 07:31
grid adaption on parallel Nurul Murad FLUENT 0 May 28, 2002 04:34
How much is the refine threshold for grid adaption Jie FLUENT 0 February 21, 2002 01:43
