pressure as udf variabe
Old   February 19, 2002, 18:17
Default pressure as udf variabe
sivakumar
hi all, i just wanna know what does the variable C_P(c,t) return in fluent, static/absolute pressure. thanks for the help, siva
Old   February 19, 2002, 21:33
Default Re: pressure as udf variabe
Greg Perkins
Static pressure. Get absolute pressure by adding the Operating Pressure to C_P.
By the way, why didn't you just try and test this yourself - its very easy to test which is which because there's such a big difference in the numbers.
Greg
vaporization pressure UDF Komon Fluent UDF and Scheme Programming 0 September 20, 2011 20:33
Accelerating pre and checking the mfr at exit how to hook udf to Pressure inlet(BC) kokoory Fluent UDF and Scheme Programming 0 August 17, 2011 09:20
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 12:35
calculation average pressure in a plane with UDF Vitalij FLUENT 1 April 10, 2007 04:39
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 03:15
