Meshing parent and daughter arteries
Old   February 6, 2002, 19:06
Default Meshing parent and daughter arteries
Pravir Kuma Rai
I want to draw 3 cylinders in the SAME PLANE having the dimensions specified : cyl.1-->radii-1.8cm , height-12 cm , cyl.2 and cyl.3-->radii-1.22 , height-4.76 cm
They have to be drawn such that it looks like Parent(cyl.1) and Daughter arteries(cyl.2 and 3). How do I draw it such that I can mesh the resulting geometry by hexahedral meshing.
Old   February 9, 2002, 12:54
Default Re: Meshing parent and daughter arteries
sharad Dugad
if you have gambit tutirial guide, try tutorial on "three pipe junction", I hope you will get further ideas how to make relevant changes to obtain the geometry as you require it to be!
Old   February 11, 2002, 20:16
Pravir Kumar Rai
I have done the 3 pipe intersection but my problem is that all the 3 pipes are in same plane unlike in the tutorial problem.So how do I make separate volumes after uniting them by the sphere.
