Compiling UDF
Old   January 31, 2002, 04:05
Default Compiling UDF
Zhang_clement
Hello everyone!
After I input the command :make "FLUENT_ARCH=irix6r10"
The following information appear:
.... sh: cc: not found error code 127 (bu21) "libudf.so" not remade because of errors (bu14) ....
Anyone know how to solved it?
I am pretty sure that my UDF code was right because it can run smoothly in "interpreted" mode.
Have a nice day!
Old   January 31, 2002, 06:11
Default Re: Compiling UDF
chiseung
That error means your unix machine doesn't have a C compiler. Get the compiler that is fit to your unix machine.
Old   February 1, 2002, 04:50
Zhang_clement
Thanks! But some other problems come out.
This is the UDF I use: DEFINE_SOURCE(Esource_ball, cell, thread, dS, eqn)
When compiling, it give the message like this:
The parametr "ds" was never referenced. The parametr "eqn" was never referenced.
What is the possible reason for this message?
Old   February 1, 2002, 11:10
kevin
you can detail explain your problem in here , i operated software of FLUENT for a lot times so , i hope to assist you to solve problem ...
Hsin-Ping-Chang
Old   February 2, 2002, 00:26
Zhang_clement
Thanks!
When comiling the following code, some error messages will give like this:
cc-3201 cc: REMARK file= source.c, line=9 The parameter "eqn" was never referenced
By the way, how to build a ellipse volume in Gambit 1.3.
Have a nice day!
#include "udf.h"
extern Domain* domain; cell_t c; face_t f; Thread *t; Domain *d; int i; DEFINE_SOURCE(Gsource_ball, cell, thread, dS, eqn) {
float source, volume, temp, mass1,mass2, den1,stand,avgc;
float mass3, mass4, mass5, mass6,mass7,mass8,cleft;
thread_loop_c (thread, domain)
{switch (THREAD_ID(thread))
case(6):
begin_c_loop_all(cell,thread)
volume=C_VOLUME(cell, thread);
temp = C_YI(cell, thread, 0);
den1 = C_R(cell, thread);
mass6 +=temp*volume*den1;
end_c_loop_all(cell, thread)
case(7):
mass7 +=temp*volume*den1;
case(8):
mass8 +=temp*volume*den1;
stand = mass1+mass2+mass3+mass4+mass5+mass6+mass7+mass8;
avgc = mass7/1.491848e-11;
if (RP_Get_Real("flow-time") <= 24*24*3600 && 5*0.45 >= avgc && stand <= 0.8*7.800317e-11*13.5)
cleft = (1.491848e-11*13.5-mass8-mass7)/1.491848e-11;
source=1.38889e-7*(5*0.45-avgc)+3.086e-8*cleft;
else
source=0;
return source; }
Old   February 3, 2002, 01:56
kevin
please added this item (eqn) inside your program . error message told you that your program must exist the argument of "eqn" , because you defined the argument[DEFINE_SOURCE(Gsource_ball, cell, thread, dS, eqn)] previously .but , you didn't write this argument(eqn)in above model. so , you can modify this code of program ,
For example: **************** source=13*P+201; /*P is variable */ ds[eqn]=201; ****************
compiling my Udf noa Fluent UDF and Scheme Programming 8 November 7, 2018 21:08
compiling udf at window Nt(64BIT) noa FLUENT 3 July 30, 2014 00:01
UDF compiling problem in Flient 6.3 jeevan kumar FLUENT 2 February 25, 2009 01:43
udf compiling problem akr FLUENT 3 August 22, 2007 08:14
On Compiling a UDF David Chabot FLUENT 5 May 20, 2005 10:13
