i have a problem about defining density~??
Old   January 30, 2002, 09:46
Default i have a problem about defining density~??
hsin ping chang
Hi....my dear friend I found the mode of mixture viscosity in my model is similar with the definition of non-ideal gas mixtures viscosity in FLUENT 5.5 user¡¦s guide, therefore, I presumed the mode of density is non-ideal-gas either. Principally because I think for the same species there should be consistency properties in the same model, e.g. viscosity is defined with a non-ideal-gas property, and then density should not be defined by using incompressible-ideal-gas mode. I wonder whether you agree with it or not? Please let me know what sort of density mode you chose in your mind and why? Thank you very much.
Old   January 30, 2002, 20:35
Default Re: i have a problem about defining density~??
Jin-Wook LEE
Ideal-gas model or incompressible-ideal-gas model is enough for for most species.
Which species are you considering for your simulation ?
Sincerely, Jinwook
Defining "cyclic" B.C. problem maysmech OpenFOAM 20 March 14, 2011 11:28
Can I solve this problem by Fluent? Kai_kc FLUENT 1 October 27, 2010 06:29
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
problem defining inlet velocity direction salman FLUENT 3 January 3, 2007 12:34
