January 28, 2002, 11:53 |
the max iteration numbers in one time step
solving unsteady flow, there is a max itration numbers in one time step. what's meanning. whether or not the solution will turn to next time step if it couldn't reach a convergence solution for max iteration numbers in this time step. if i want to reach a convergence solution for every time step, what shall i do? thanks
January 28, 2002, 12:35 |
Re: the max iteration numbers in one time step
You could increase the number of max iteration in one time step to an important value like for example 100000. |
January 29, 2002, 11:39 |
is that the only way? thanks
January 30, 2002, 09:23 |
Best thing is to reduce time step size until the residuals drop by two-three orders of magnitude in 5-10 iterations per time step.
February 1, 2002, 11:24 |
thanks for mw, hvn
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 12:08 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 06:24 |
Full pipe 3D using icoFoam | cyberbrain | OpenFOAM | 4 | March 16, 2011 10:20 |
SimpleFoam k and epsilon bounded | nedved | OpenFOAM Running, Solving & CFD | 1 | November 25, 2008 21:21 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 03:58 |
