Grid type in GAMBIT
Old   January 18, 2002, 06:11
Default Grid type in GAMBIT
Christian
Hi.
I have a problem meshing a volume. I have meshed all the surfaces with squares, but when I try to mesh the volume with the Cooper tool, I get an error. Gambit wants to mesh the volume with tri's.
Does anyone know why I cannot mesh with Hex cells when all the faces are meshed with squares ? Is it again the vertex types that are to blame ?
Cheers Christian
Old   January 18, 2002, 11:12
Default Re: Grid type in GAMBIT
Erwin
First of all, if you mesh all faces with quads that's no guarantee that your volume is mappable or cooperable. Check to manual to see if your volume adheres to the requirements for Coopertool (needs to be a barrel with 2 endcaps).
If it is possible to Cooper but Gambit can only come up with a TGrid scheme, that's because Gambit is sometimes to dumb to figure it out by itself. You can force it to Cooper by setting Element to Hex or Hex/Wedge, and then to select the Type as Cooper. This usually also means that you have to specify all source faces.
Be sure to select your 'target' source face last. Be also sure not to have a mesh on your target face.
Free jet simulation msarkar OpenFOAM Running, Solving & CFD 39 May 11, 2021 14:21
Flow Around a Cylinder ronaldo OpenFOAM 5 September 18, 2009 09:13
pipe with buoyantFoam buoyancy, boundary conditions Thomas Baumann OpenFOAM 0 June 15, 2009 09:58
FOAM FATAL IO ERRORsimpleFoam hariya03 OpenFOAM Running, Solving & CFD 6 July 16, 2008 09:03
RasInterFoam STRANGE RESULTS AT BOUNDARY kumar2 OpenFOAM Running, Solving & CFD 8 March 24, 2008 19:38
