User-Defined Functions
Old   January 16, 2002, 11:47
Default User-Defined Functions
Boisson
I want to compile two User-Defined functions in order to use them in the Boundary Conditions panel. So I have created my two functions. Then I have compiled sucessfully the two functions, one after the other. But when I open the boundary conditions panel (pressure inlet), there is only one function available. The first function compiled has been replaced by the second one. How it is possible to obtain several functions in the boundary conditions panel? I tried to create a library with two functions, but I didn't find anough information in the Help to perform it.
Thanks for your help.
Old   January 16, 2002, 12:55
Default Re: User-Defined Functions
Markus
Hi Boisson
It's a good idea to write both DEFINE-functions in a single c-source file, give them different names and compile the single source file.
yours Markus
Old   January 18, 2002, 23:09
Greg Perkins
there's no need to have the udfs in a single file.
if you have multiple files, you need to list them in your makefile.
If you have two or more functions, they must be compiled simulataneously, either in a single source file or in mutliple files. You can't compile one after the other into a single library using the fluent make files as supplied.
Greg
USER DEFINED SCALARS yann Phoenics 6 November 14, 2013 09:46
Wall Treatment of User defined Turbulence Model Yang Chung FLUENT 0 August 23, 2008 12:31
User Defined Scalars - Returning Values Carlos V. FLUENT 0 April 19, 2006 19:18
Source term for user defined scalars Mech.eng. Siemens 0 March 16, 2006 07:15
User defined functions Tuomas Koiranen FLUENT 2 December 29, 1999 08:41
