HVN tell me the detail of relative pressure
Old   December 31, 2001, 03:29
Default HVN tell me the detail of relative pressure
chong chee nan
please tell me how to get relative pressure, i mean the solution or the formula calculation. and the outlet pressure shown in a straight line that mean all the point and the outlet have same value of pressure. can u give me your mail address.
Old   January 2, 2002, 05:55
Default Re: HVN tell me the detail of relative pressure
Jin-Wook LEE
For incompressible flow simulation, the relative pressure can be considered as the difference from the given(or assumed) value at the given point. Given point might be arbitrary. That is, if you know the pressure at the outlet, you can add the pressure difference between the outlet(where you know the pressure) and the each point, and you can obtain the real pressure.
Example :
- You know outlet pressure, say 101325 Pa
- Outlet pressure of CFD result, say -100Pa
- CFD result for the pressure at the certain point, say -50 Pa.
Don't stick at the value of -100 or -50, You can interprete the result as, presuure at the outlet is 101325Pa(which you have information) and the pressure at the certain point is 101325-(-50)=101375 Pa.
Sincerely, Jinwook
"Pressure Inlet" Boundary Setup Wijaya FLUENT 15 May 18, 2016 11:08
pressure BC-natural convection engahmed Main CFD Forum 0 June 16, 2010 12:38
pressure in Natural convection??? engahmed FLUENT 0 June 14, 2010 13:51
Pressure Rise Error emueller CFX 0 May 5, 2009 12:08
Negative Pressure in fan modelling Jenny CFX 3 September 30, 2007 09:47
