Ensight - node values -cell values
Old   December 24, 2001, 10:57
Default Ensight - node values -cell values
leo
Hi there,
I have already completed an analysisi and would like to postprocess using Ensight v 7.3. So I exported the geometry and the data . The functions I exported were press, temp, vel, surfa. heat flux, surf. heat. tra. coeff.. But when I checked the scalar outpu file for surfa. heat flux abd surf. heat. tra. coeff I saw file full of 0's. Note that Fluent 5.5 can not display these last two variables as node values so all values for these two variables are 0.0 in the export file
So any suggestions for exporting those cell values in Ensight format, i.e. nodal values ?
Regards
Leo
Old   May 12, 2010, 09:47
Default EnSight with Fluent options
Darin McKinnis
darinmckinnis is on a distinguished road
Hi Leo,
This is later in time. But perhaps someone else is looking for similar information....
There is now a direct reader for Fluent files in EnSight 8.2 and later. So that's one option.
Another option is to read the EnSight Case files into ens_checker which is a utility to check the format of EnSight Case files. All copies of EnSight include ens_checker, more recent versions provide better checking. So it would again be good to get the latest version, 9.1 or later, for that.
Finally you could recommend to ANSYS that they use CEI's EnSight Case file API to correctly write the file format. There is no charge for the API from CEI.
Regards,
Darin
Originally Posted by leo
;99205
Hi there,
Regards
Leo
darinmckinnis is offline   Reply With Quote
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 22:58
Cell face values computation un unstructured grids Sergio Rossi Main CFD Forum 2 May 28, 2006 11:04
Printing node values maka OpenFOAM Pre-Processing 0 November 18, 2005 06:03
Node centered and cell centered. Confused. Main CFD Forum 9 August 29, 2003 14:54
Help: how to get node values with UDF? Dazhi Guo FLUENT 0 February 4, 2001 01:59
