SOx calculation
Old   December 18, 2001, 13:25
Default SOx calculation
olivier
Hi I would like to modelise formation of SO2 and SO3 in a chamber of combustion I have no idea about the kinetics of reaction of the formation of SOx and therefore I don't know if I could use PDF to ontain my results?
any references are welcome
thanks a lot Olivier
Old   December 19, 2001, 06:55
Default Re: SOx calculation
Jin-Wook LEE
As far as I know, Sulphur is very fastly reactive, so that, I think, you can use PDF model, which is, as you know, based on 'fast chemistry'.
Sincerely, Jinwook
Old   December 19, 2001, 07:09
olivier
I thank you very much for your help. I will try it with PDF. thanks Olivier
Old   December 19, 2001, 22:58
Jin-Wook LEE
Then, would you tell me why you need sulphur modeling ? NOx generation is dependent on the combustion environment. But, as a enginnering view, it is fairly realistic to assume that all sulphur in the fuel is converted to the mostly SO2(more than 90%) and partly SO3.
Sincerely, Jinwook
Old   January 17, 2002, 12:49
olivier
Hi JIN first I wish you the best for the new year to answer you, I am very interested to calculate SOx in order to evaluate the impact on the environment of the formation of SO3 and evaluate H2SO4.
regards olivier
Transfer output data as input for second calculation mannobot Main CFD Forum 3 December 7, 2018 10:37
MRF and Heat transfer calculation Susan YU FLUENT 0 June 2, 2010 09:46
Defining output as input for second calculation mannobot FLUENT 1 June 2, 2010 05:20
Warning 097- AB Siemens 6 November 15, 2004 05:41
Heat Flux Calculation under REPORTS Alberto Schroth FLUENT 0 May 16, 2000 09:19
