absolute pressure limited
Old   December 7, 2001, 12:22
Default absolute pressure limited
Boisson
I want to fill a bottle of gaz with a inlet pressure of 300 bars. The solver is coupled explicit, rke, unsteady. Then I choose the following boundary conditions : the entry is defined as a pressure-inlet; Gauge Total Pressure= 833e5 Pa, Supersonic/Initial Gauge Pressure= 300e5 Pa (in order to have Mach=1 at the entry), T=300 K. During the calcul the "absolute pressure is limited to 50e5 Pa in 30 cells". Consequently the pressure in the bottle can't reach the wanted pressure (300 b). I would like to know why the pressure is limited and how it is possible to change this maximum.
Thanks.
Old   December 9, 2001, 14:21
Default Re: absolute pressure limited
Alain
You can change this value in solve/controls/limits menu.
best regards
Alain
absolute negative pressure???? john Siemens 6 December 12, 2014 01:18
Setting minimum absolute pressure limit meteo45fr STAR-CCM+ 2 May 25, 2009 03:59
Absolute pressure...pls help Peter FLUENT 1 July 12, 2008 14:46
absolute and total pressure novice FLUENT 2 May 26, 2008 19:48
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 03:15
