December 5, 2001, 14:20 |
properties on the grid next to the wall
Dear all,
I need some fluid properties such as temperature, pressure, etc just next to the solid wall. I have tried on the XY plot, but it can only give the properties on the wall, inlet, and outlet. Thanks, raharjo |
December 6, 2001, 15:21 |
Re: properties on the grid next to the wall
You have to define the line or the plane where you want to monitor your data, then you use XY-plot.
December 7, 2001, 13:59 |
I'll try, thanks a lot
Raharjo |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 01:04 |
Deal with wall boundary with moving mesh by FVM? | aiya | Main CFD Forum | 6 | May 10, 2007 12:33 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 06:12 |
wall function and grid dependency | Bob | Main CFD Forum | 10 | April 28, 2004 03:15 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
