Flat Plate And LES
Old   December 2, 2001, 22:44
Default Flat Plate And LES
Chetan Kadakia
I am modeling laminar flow past a flat plate. Using Blausius's solution, I can obtaint the boundary layer thicknesses and the CD. I compare these results to my steady solutions in Fluent. When I select the laminar and k-epsilon RNG model, I match Blausius's solution. But when I try Large Eddy Simulation, which will be unsteady without choice, I have difficulties. I have trouble converging the solution, and obtaining accurate Cd values. I believe that lamainar flow can be modeled with some accuracy when using LES with low value turbulent boundary conditions, but I cannot get this to work. Please help me so I can move on to further solutions with LES.
Wall Acoustic pressure prediction on a flat plate using ffowcs-williams & Hawkings maxkcng FLUENT 2 October 11, 2012 03:25
Modeling vortex creation past vertical flat wall LES model shackman287 OpenFOAM 0 August 17, 2010 19:51
Mapping RANS data onto an LES christian OpenFOAM Running, Solving & CFD 0 April 13, 2007 06:31
'Fluent for Flat Plate Oscillatory BL Transition Jay FLUENT 11 July 11, 2002 06:48
2D Flat Plate Oscillatory BL Transition Jayd Main CFD Forum 2 June 18, 2002 09:02
