calc time
Old   November 27, 2001, 14:15
Default calc time
Andrew Parker
Dear all
Does anybody know if it is possible to find the total computational time in hours, minutes, and seconds of a case and data file? I cannot find this in the menus and wondered if there was a text command, to tell you how long a case had been run.
Cheers
Andy
P.S. I am using Fluent 5.5.14
Old   November 28, 2001, 04:00
Default Re: calc time
lhb
In NT, when iteration is finished, you can look in taskmanager, the cpu time a program use can be found there.
Old   November 28, 2001, 11:14
zc
On NT you can use journal or scheme lenguage and rederect time in some file like that: !time /t > test.txt --> your work in fluent until convergence !time /t >> test.txt
On Unix something like above: !date > ./test.txt --> your work in fluent until convergence !date >> ./test.txt
Old   November 28, 2001, 11:18
zc
Sorry, this is correct:
!time /t > test.txt
!date > ./test.txt
!date >> ./test.txt
Old   November 29, 2001, 06:10
Karl
For the serial solver, you can measure the time spent iterating in Fluent through the use of a scheme file " benchmark.scm ". This file can be accessed through the Fluent User Services Center (www.fluentusers.com). Have a look under Fluent 5 - FAQ.
If you are running the parallel version, you can use the Parallel -> Timer feature.
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 17, 2019 00:12
Hydrostatic Pressure and Gravity miliante OpenFOAM Running, Solving & CFD 132 October 7, 2012 23:50
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 06:24
Problems with simulating TurbFOAM barath.ezhilan OpenFOAM 13 July 16, 2009 06:55
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
