two adjacent cell zones.
Old   November 21, 2001, 00:45
Default two adjacent cell zones.
Thejasvi
what does this mean "Error: pressure-outlet zone 3 has two adjacent cell zones." This is the error when doing the grid check.The pressure outlet zone 3 corresponds to a set of holes connecting two fluids;from the inner tube the fluid hits the inner surface of the external tube thru' these holes. please suggest help..
Old   November 21, 2001, 04:16
Default Re: two adjacent cell zones.
Jan Erik
Hi! pressure outlet cannot have comp. cells on both sides of the face. Therefore u'll have to create an "empty box" sort of to define pressure otlet b.c.
Old   November 21, 2001, 06:44
Thejasvi
actually a pressure outlet condition is not required on the holes .The condition to be specified is just outflow(no prior information is know here,except the fact that the fluid emerges out of these holes and hits a surface.) with outflow b.c the grid check fails.please suggest a method so that outflow b.c can be successfully applied.
Old   November 26, 2001, 09:35
Jan Erik
why not interior faces? havent read u'r problem properly due to lack of free time ...
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 22:58
Velocity Inlet zone has two adjacent Cell zones Mohsin FLUENT 0 March 10, 2010 03:12
adjacent cell zones Louisa FLUENT 4 August 31, 2007 07:49
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
Warning 097- AB Siemens 6 November 15, 2004 05:41
