Two phase flow problem
Old   November 9, 2001, 16:17
Default Two phase flow problem
M.Shannag
I am trying to solve an isothermal, laminar, and steady 2D two phase (Air-water) flow problem using Fluent 5.4. The used multiphase model is VOF and the model scheme is implicit. Simply the flow problem represented by a liquid water filled an enclosure and it is driven by a stream of air.
Could you please help me to solve the following error:
Error: Internal error at line 1645 in file 'sg_mphase.c'. bc type not handled Update_Fluid_Density Error Object: ()
and what do you recommend me in solving this air-water problem Many Thanks, M. Shannag
Old   November 11, 2001, 23:21
Default Re: Two phase flow problem
Newbie
Are you using a UDS? Anyway search about the difficulties and advising given in other posts on this forum.
Rgds
Newbie
Old   December 29, 2001, 13:43
Tamer Elsoukkary
can you e-mail me your cas and dat files
error in two phase flow problem mvee FLUENT 0 March 28, 2007 06:17
LES on two phase flow Li Yang Main CFD Forum 0 May 12, 2004 09:10
Two-phase/ Single phase mix flow Reza Main CFD Forum 1 August 6, 2003 07:36
compressible two phase flow in CFX4.4 youngan CFX 0 July 2, 2003 00:32
Poiseuille flow problem Rosie FLUENT 1 December 6, 2002 17:52
