outflow BC
Old   November 8, 2001, 09:28
Default outflow BC
Niklas
How is the "outflow" BC defined in fluent5?
thanks
N
Old   November 8, 2001, 09:58
Default Re: outflow BC
chang hisn ping
The fluent's manual have talked the info .you can try for manual's ( 6.2.1 using flow boundary conditions) **outflow boundary condition are used to model flow exits where the details of the flow velocity and pressure are not known prior to solution of the flow problem , if you want to know the detail info >>>>look manual
Old   December 25, 2001, 12:42
Lakshmanagouda. .G.patil
flow should be uniform ... no reverse flows pl... otherwise it will take lot of your effort. bye
Outflow boundary Control Volume SIMPLE Help !!! Mizerable Main CFD Forum 4 August 22, 2011 14:00
No outflow - Error sErik OpenFOAM Running, Solving & CFD 1 November 18, 2009 12:10
mass flux correction at outflow boundaries Subhra Datta Main CFD Forum 2 November 24, 2003 14:11
outflow boudary condition in SIMPLE algorithm dallybird Main CFD Forum 0 March 6, 2003 12:55
Outflow Bocos Romuald Skoda Main CFD Forum 3 August 6, 1999 04:08
