error while running UDF
Old   October 20, 2001, 23:07
Default error while running UDF
murthy
Hi, I have succesfully compiled my UDF and imported the library files to theis respective conditions.But when I try to solve(iterate),Fluent 5.5.14 shows me an error which states segmentation violation.I am using the UDF's for x momentum and Y-momentum source terms. Could any body tell me what this error is about. Thanks in advance, Murthy
Old   October 22, 2001, 06:02
Default Re: error while running UDF
Michele Cagna
It's hard to say what the error is about without a more detailed description of the source-code.
I had a similar occurence when i used variables of the Type C_U_M1(c,t).
Perhaps you can describe the problem more precisely.
Ciao
M.C.
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
Help Parallelizing UDF AndresC FLUENT 0 February 25, 2010 16:50
A Loop problem when running UDF in the batch mode Jun Geng FLUENT 3 July 16, 2008 09:34
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 05:03
UDF : Chemical Reaction in Catalytic Converter adhimac FLUENT 1 March 27, 2001 15:04
