Tecplot can't read data file from Fluent.
Old   October 11, 2001, 14:32
Default Tecplot can't read data file from Fluent.
stephen
Hi,everyone.I meet a problem when I use Tecplot to load a data file. My question is: why Tecplot can't read a data file exported automatically from Fluent5.5 with tecplot file type? My tecplot version is 9.0-0-9(03-26-2001). I hope to get your help. Thanks.
Here is the head of a data file exported from Fluent:
TITLE = "title" VARIABLES = X, Y, "Static Pressure", "Pressure Coefficient", "X Velocity", "Y Velocity", "Mach Number", "Static Temperature", "Turbulent Kinetic Energy (k)", "Turbulent Dissipation Rate (Epsilon)", "Turbulent Viscosity Ratio" ZONE T="default-interior", N=40497, E=79500, ET=LINE, F=FEBLOCK
When I used Tecplot to load it, an error occurred. Here is the error message:
Err: Invalid Element type,Need TRIANGLE,QUADRILATERAL,TETRAHEDRON,or BRICK Error occurred on line number 3
Old   October 12, 2001, 04:09
Default Re: Tecplot can't read data file from Fluent.
Giovanni
I don't remeber the version, but some months ago I met with a similar problem. You need an updating.
Giovanni
Old   October 12, 2001, 13:18
stephen
Thank you very much,Giovanni. I'll get an updating version.
Old   October 26, 2001, 17:54
Sonny
I have had similar problems as you described above when I have exported a fluent solution from the parallel solver to Fieldview. I solved this problem by exporting from a single-CPU solver.
Old   October 28, 2001, 17:06
reza pegah
Old   November 1, 2001, 11:05
Kevin
Which to update? Tecplot or Fluent?
Well, I use TECPLOT 9.0 and FLUENT 5.4.8, both are the most current versions. But still I have the same problem. So, updating doesn't seem to work for me.
Help, please! Kevin
Old   November 1, 2001, 11:15
Kevin
I got it now! It is not the version. It is a mistake. I should not have selected any "Surfaces", only just have to select variables I want.
Alright, thanks,
Kevin
Old   November 1, 2001, 13:59
stephen
I also found it isn't the problem of version. you got the point. thank you.
Old   November 21, 2001, 21:27
don
The problem is due to an error in the Fluent exporter for Tecplot files. It includes an element type, ET=LINE, but Tecplot does not support the line element type. Therefore, Tecplot issues the error message you reported. Have you tried using the Fluent data loader that is provided with Tecplot? It reads the native Fluent Case and Data files directly. Also, there are patches for more recent releases of Tecplot 9.0 on the Amtec web site.
2.0.x on Mac OSX niklas OpenFOAM Installation 74 March 28, 2012 17:46
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 10:50
OpenFOAM Install Script ljsh OpenFOAM Installation 82 October 12, 2009 12:47
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 16:16
