problems with free surface
Old   October 9, 2001, 09:51
Default problems with free surface
seba
i have a question.. do the calculations including free surface need using two phases? I need to use heat exchange but this is not possible when i use multiphase flow... thank you for help.. seba
Old   October 11, 2001, 19:32
Default Re: problems with free surface
Raja Banerjee
To solve free surface flows in FLUENT, you have to use VOF model and the present version does not incorporate heat transfer. You may be able to solve the energy equation by using the User Defined Scalar equations. Relatively simple scalar conservation equations can be solved using this option. Thanks Raja
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 12:12
Linear analytical solution oto the 2D free sloshing water surface elevation bearcat Main CFD Forum 7 August 5, 2011 21:13
Equilibrium of a free surface under surface tensio Ryan Main CFD Forum 1 August 7, 2001 17:14
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
sphere in a free surface (thin film)flow Vasu Veerapaneni Main CFD Forum 0 September 15, 1998 18:32
