Power Used On moving Fluid
Old   September 25, 2001, 16:53
Default Power Used On moving Fluid
Amadou Sowe
Fluent 5 post processing matter: I am trying to compute the power used by a vibrating plate on moving the fluid above it using fluent 5. One approach I have is to integrate an appropriate custom field function using surface integrals under the reports menu. Does any one have a better way or an improvement to my idea?
Old   September 26, 2001, 13:29
Default Re: Power Used On moving Fluid
Lanre
Hi Amadou,
Either a CFF or a UDF utilizing the execute on demand macro would work. The latter approach with the UDF would give you more flexibility particularly if the plate is non-planar and you can also write the function to user-defined memory so that you can display contours of the power on the plate. A simple alternative would be to use the Report->Forces... panel to compute the force on the plate and then hand- calc to power.
Cheers, Lanre
Old   September 26, 2001, 13:50
Amadou Sowe
Hi Lanre, Thanks for your input. The force on the plate is not constant so the last option (Report-->Forces) is not as applicable as the first two. The CFF approach is the one I am using currently.
However, your second approach would be really good to do since I can plot contours of power on the plate. Unfortunately, I am not familiar with this approach. I will be more than glad to know the specifics on using a UDF to achieve this task.
Old   September 26, 2001, 14:44
Lanre
Hi Amadou,
This example walks you through the basics of my second suggestion:
http://www.fluentusers.com/fluent5/d...ml/node108.htm
You'll need to compute the shear stress on the plate (wall) zone to use in the power calculation.
Cheers, Lanre
Old   September 26, 2001, 15:03
Amadou Sowe
Thanks Lanre, I will pursue it.
CFX non newtonian power law fluid Mehmet SORGUN CFX 4 October 13, 2013 11:25
How to apply negtive pressure to outlet bioman66 CFX 5 June 3, 2006 02:40
moving wall and fluid soody FLUENT 3 September 20, 2004 02:37
CFD and fluid power components Paul Hancock Main CFD Forum 4 June 14, 1999 07:15
Why FVM for high-Re flows? Zhong Lei Main CFD Forum 23 May 14, 1999 14:22
