September 23, 2001, 04:52 |
Multi-phase
HI, guys
I have a question to ask u guys. Can Fluent model the multi-phase flow containing multi-species? For example, i want to simulate a solution containing solvents with high volatility be deposited on a spinning disk, can i solve this question by fluent? Thanks |
September 26, 2001, 13:43 |
Re: Multi-phase
What is the mechanism of deposition? Are these droplets impinging on a spinning disk?
October 1, 2001, 16:25 |
Re: Multi-phase
NO, in this problem i assume it is already have a film coated on the disk, then rotate the disk with high speed. At the same time, the solvent contain in the film evaporating cause the viscosity of the film become hard to spread out. So i wanna use Fluent to model this situation. But i never success.
could u give me a hand? thanks a lot. |
alphaEqn.H in twoPhaseEulerFoam | cheng1988sjtu | OpenFOAM Bugs | 15 | May 1, 2016 17:12 |
using interface with Euler multi phase model | karimi | FLUENT | 0 | May 22, 2011 03:46 |
using interface with Euler multi phase model | karimi | Main CFD Forum | 0 | May 22, 2011 03:39 |
Multi phase heat exchange simulation. | JP | CFX | 1 | May 26, 2008 06:22 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 2, 2003 00:32 |
