September 5, 2001, 12:24 |
hexa/wedge interface
Hi
I have a mesh with hexas which can sometimes be next to two wedges. i.e the quad face of the hexa joins the two triangle faces of the wedges. How can I get fluent to cope with this set up. It works fine in STAR-CD !! Can I simply call each of the faces in question an interface boundary ?? Regards Mark |
October 4, 2001, 21:26 |
Re: hexa/wedge interface
There is no easy solution but there is a workround. What you need to do is collect all your faces which are not matching into 2 groups, one for the hex faces, one for the tri faces. Then set BC type of each zone to "Interface" Then go into Define --> Interfaces (I think). And make the two zones a pair of interfaces.
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 05:45 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
CFX Solver Memory Error | mike | CFX | 1 | March 19, 2008 07:22 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 20:09 |
