PDF problem
Old   August 29, 2001, 13:38
Default PDF problem
olivier
Hi I would like to create a non adiabatique PDF case to simulate a solid combustion in Fluent v5. I briefly describe the problem I have. The fuel considered is known to consist of 46% volatiles and 54% char. There is no ash. I have a known mole fraction CHONS composition (C=39.4% ; H = 52.2 %; O = 6.9% ; N = 1.13% ; S = 0.430%)and I know the lower heating value (30 e+06 J/kg). I don't know the value of the heat capacity of the fuel but I let a value of 1000J/kgK. 1/ I assume that the equilibrium system consists of 13 species (CHONS, C(S), S(S), SO2,NO2,CO2,H2O, N2,O2). that means a simple form. 2/The "empirically defined streams" consist of a FUEL STREAM 3/ My operating conditions are 101000Pa for pressure, 400K for the fuel and 555K for the oxidiser. Min temp =300K ansd max temp = 3500K.
PROBLEM I cannot calculate the pdf case with my LCV (J/kg)and if I modify this value to 45 e+06J/kg I have no problems and I obtain values .
Could someone able to help me to resolve this problem Because it's the first time I use the "fuel stream option" , may be I have forgotten something... all informations about my problem will be very kind. Thanks
Old   September 5, 2001, 00:54
Default Re: PDF problem
Jin-Wook LEE
1. Select more species which is possible even though it's life cycle may be very short. Possible species are, for example, CH4, C2H2, OH and so on.
2. Additional comments :
1) Simplify your problem. That is neglet minor species or less meaningful species in the fuel, if possible, such as S(S), SO2, N......, if possible. In general, they can be neglected.
2) NO and/or NO2 is not good choice because it's chemistry is not based on the equilibrium chemistry.
Sincerely, Jinwook
Old   September 5, 2001, 04:45
olivier
Thank you I will try your advice and give you the results. bye
Olivier
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 20:42
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
Non-premixed comb. temp prediction; PDF problem K. Jagus FLUENT 4 October 5, 2005 09:32
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 15:52
