August 23, 2001, 09:15 |
Porous media flow
dear Fluent Users/Enthusiasts,
please, how good is fluent for incompressible, slow flows, and how good will it be in treating porous media flows |
August 23, 2001, 17:19 |
Re: Porous media flow
We've been using FLUENT for low velocity incompressible flows through porous media for years. Once we worked out good underrelaxation ranges to use, there have been no problems.
August 24, 2001, 02:53 |
Hallo Evan, I also work with porous media, and I have often the problem that the residuals of continuity does not decrease under 0,003. What can I do and what underrelexation ranges do you use?
Yours Armin |
August 24, 2001, 06:33 |
Hi!
Unfortunately, Fluent cannot do transient flow through porous media. It is only an approximation through resistances and the porosity iteslf is not taken into account. This can cause serious errors in the transient term. |
August 24, 2001, 07:45 |
I know it is approximated by the law of Darcy. But I am interested in Evan`s underrelaxation ranges...
Yours Armin |
August 24, 2001, 12:19 |
Thanks for your message Evan. please, do your simulations have free surfaces in them. And do you know more about the transient problem, the other contributor has mentioned about
August 24, 2001, 13:52 |
We don't use the free surface model. We just use a wall with a slip BC and use the PRESTO! pressure scheme. Experience with actual equipment tells us we have very little water motion near the surface, so it works for us.
We haven't had any trouble with transients, although we don't do that many. Yes, it's an approximation. But it's not a bad approximation for some conditions. Our velocities are practically diffusion flow, so it works OK. As for underrelaxations (for Armin) we try to stick with values near the following: Pressure = 0.3, Momentum = 0.7, Energy = 1, TKE = 0.6, Dissipation = 0.6, Visc = 0.6, Den = 0.95, BF = 0.95 These are used with very high IRFs and buoyancy-dominated flows, so they may not work at all for you. |
August 27, 2001, 14:11 |
Be aware that there is no true turbulence in terms of energy cascading from large to small eddies if the bed porosity is too low. In that case unimpeded eddies of arbitrary size are impossible and conventional k-e models are not applicable. A specific turbulence model is required to account for the occurrence of void and pseudo vortices and to account for the size limitations of eddies (canot be bigger than the biggest opening in porous medium). This model is not available in Fluent.
September 1, 2001, 22:55 |
#9 |
Hi, Mr. Erwin, can you provide me some references about the model you mention?
Thanks Newbie |
September 7, 2001, 10:03 |
#10 |
Sorry for my late reply, I was on a trip.
References: Turbulence Model for flow through porous media - T. Matsuoka and Y. Takatsu - Int. J. Heat Mass Transfer, Vol.39, No 13, 1996 A general two-equation macroscopic turbulence model for incompressible flow in porous media - B. Antohe, J. Lage - Int. J. Heat Mass Transfer, Vol.40, No 13, 1997 |
September 10, 2001, 14:05 |
#11 |
Thanks for the information.
Regards newbie |
March 2, 2010, 08:19 |
#12 |
Serena
hi, Erwin
i am simulating the flow that thorough the perforated plate,now i am stumped to determine the direction vectors of the resistance coefficient. my plate is wave-shaped,so the direction vectors is not simple to define as X Y or Z,i don't know how to deal with this ,could you help me? thanks ,sincerely |
March 2, 2010, 08:20 |
#13 |
Serena
hi, Erwin
How to model granular flow through porous media | Axius | FLUENT | 2 | August 7, 2014 11:34 |
Compressible flow through porous media? | JoFFe | CFX | 2 | November 1, 2010 05:50 |
no converge - for Low Re Porous media seepage flow | lee | CFX | 3 | August 31, 2007 02:12 |
Modeling porous media flow in prostar | Nirmal Kumar Pathak | Siemens | 8 | November 23, 2005 08:18 |
Flow resistance of porous media | Desheng Kong | Main CFD Forum | 3 | December 19, 2000 12:07 |
