outlet massflow boundary condition ??
Old   August 17, 2001, 06:44
Default outlet massflow boundary condition ??
Charles Renard
hi !
i am wondering how to model a fresh air entry on a vehicle.(i am currently working on external aerodynamics) i already modeled the corresponding hot gases oulet with a mass flow inlet boundary condition.
my issue is that i only know the mass flow rate (the same as for hot gases outlet), and it seems that fluent 5 has no "outlet massflow" boundary condition.
Help needed !
thanks Charles
Old   August 19, 2001, 03:05
Default Re: outlet massflow boundary condition ??
Chetan Kadakia
Use 'outflow' for your exit BC. This is a simple BC that I beleive says that your inlet massflow(s) is equal to the outlet here (when flow weighting is 1).
Old   August 19, 2001, 12:44
Mark Richardson
Charles, I have not done this to test my theory but is a mass outflow just a negative mass inflow?
When I check the fluxes (Report->Fluxes, compute) I get opposite values of equal magnitude at my pressure inlet and pressre outlet for mass flow rate.
Luck, Mark
Old   August 20, 2001, 04:23
Charles Renard
Hi !
Unfortunately, giving a negative inlet massflow doen not work, fluent doens not accept it.
as a solution to my issue, i entered a negative inlet velocity corresponding to the massflow (and area of course...). this last solution was accepted by the software and seems to work....
but i still believe it would be great to have a real outlet massflow bc in fluent ;-)
thanks Charles
Old   August 23, 2001, 17:42
Jonas Larsson
You can easily write a scheme file which updates the static pressure of a pressure-outlet to match a certain specified mass-flow. I even think that this is an example that Fluent will give to you - if you ask support I'm sure they'll send it to you. If I remember correctly it has also been posted here some time ago... found it btw, it is here.
Old   August 24, 2001, 16:47
Lanre
Don't specify negative mass, just specify the direction vector to be negative to the boundary!
Outlet Boundary Condition ashtonJ CFX 6 April 26, 2011 09:09
CFX Solver : Sudden crash Hervé CFX 2 June 16, 2008 07:40
Help needed for outlet boundary condition YY CFX 7 April 20, 2008 23:04
Outlet boundary condition CN FLUENT 6 May 22, 2005 10:37
Outlet velocity boundary condition Jay FLUENT 4 December 15, 2002 09:27
