Thin Surface in Gambit
Old   August 14, 2001, 19:41
Default Thin Surface in Gambit
cfd guy
Hi all,
Why Gambit didn't recognize a surface that I had set to wall as a thin surface? Gambit simply ignores it when I export the .msh file. I want to use the Fluent 5 solver.
So, anyone got any hint?
Regards,
cfd guy
Old   August 16, 2001, 11:40
Default Re: Thin Surface in Gambit
Jerry
First, please check if the surface belongs to volumes. If the surface is standalone, then you can't export it. Second, if the surface is "of" volumes, then if you don't mesh it, again you can't export it.
Have a nice day.
Old   August 16, 2001, 13:47
cfd guy
Thanks Jerry for answering,
As a new user I must say that Gambit didn't export the thin surface defined as WALL. I was meshing my volume with tets, is this might be the problem?
Regards,
cfd guy
surface planes in gambit falak FLUENT 11 September 12, 2014 16:38
ICEM CFD 5.0 (Hexa) - Internal Wall/Thin Surface James Date CFX 3 August 10, 2012 05:47
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 13:43
How to set a thin surface using CFX4.4? paul CFX 9 January 19, 2004 22:53
sphere in a free surface (thin film)flow Vasu Veerapaneni Main CFD Forum 0 September 15, 1998 18:32
