August 13, 2001, 23:42 |
Convergence problem
I have a model to calculate the flowfield. After 20000 interations, the residual of X-velocity is about 0.05 and will stay the same for the next 10000 interations. Can I consider it to be a convergence result?Is it too big for convergence(In fact, the default residual is 1e-3)? |
August 14, 2001, 01:04 |
Re: Convergence problem
(1). You can plot some flow variables of interest to you vs number of iterations. This is the only meaningful way to determine the solution convergence. (2). If these flow parameters oscillate, then you have some convergence problems. (3). The more accurate way is to use contour plots between iterations. Then you can see areas of oscillation. (I think you can plot the residuals contour plot) (4). Convergence problem can be caused by many factors, among which, mesh quality is one of the most obvious one.
convergence problem when use pisoFoam, LES for wind tunnel case | Forrest_Lei | OpenFOAM | 3 | July 19, 2011 07:00 |
convergence problem | commonyue | Main CFD Forum | 1 | December 1, 2009 04:54 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 02:17 |
3D Fluid Flow Convergence problem | Emily | FLUENT | 2 | March 21, 2007 23:18 |
Non Convergence of 3D Heat transfer cfd problem | Balraj | Main CFD Forum | 3 | December 9, 2004 01:24 |
