flow through impeller
Old   August 9, 2001, 10:00
Default flow through impeller
Bob
Hi, I would like to know if somebody managed to get a converged solution for a 3D turbulent flow through a centrifugal impeller of a pump, using fluent?
Old   August 9, 2001, 15:46
Default Re: flow through impeller
Joern Beilke
Do you want a converged or a correct solution? Just getting a converged solution is very easy ;-)
Old   August 9, 2001, 17:31
John C. Chien
(1). Yes, Both Fluent and CFX-TASCflow can be used for the radial turbine/pump impeller flow. (2). Since the flow is highly 3-D, it is hard to know whether the solution is accurate or not. (3). It is also very difficult to do measurement. (most available data were performed for 2-D configuration)
Old   August 10, 2001, 17:34
Bob
Thank you Joern Beilke and John C. Chien for your answers, indeed I'am getting converged solutions but they don't make any physical sense at all. I'll keep on trying.Ciao.
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 12:47
Fully Developed Flow in Star-cd SMM STAR-CD 0 September 5, 2011 23:08
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 09:33
reversed flow at velocity inlet / mass flow inlet ib FLUENT 1 March 26, 2007 14:11
transform navier-stokes eq. to euler-eq. pxyz Main CFD Forum 37 July 7, 2006 09:42
