reaction rate
Old   August 2, 2001, 15:18
Default reaction rate
karthick
i am modelling a diffusion flame. I am using methane as fuel and oxygen as oxidizer.I am using finite rate chemistry model. I want to know the production rates of the products and the consumption rates of reactants. can anyone help me in this regard? thanks. karthik
Old   August 2, 2001, 21:37
Default Re: reaction rate
Jin-Wook LEE
FLuent has the database for the reaction rate coefficients of methane-air reacton. I think that you can use the coefficients for methane-oxygen reaction if you do not have any alternative.
One comment : I recommend 'finite rate / eddy dissipation' rather than 'finite rate only' for the diffusion flame, if your system belong to the turbulent flow regime.
Sincerely, Jinwook
Old   August 3, 2001, 01:03
karthick
thank very much for the reply. my flow conditions lie within laminar regim. i think i must use finite rate chemistry and i am using the database values as inputs to the finite rate chemistry calculation in the fluent. but after some iterations i want to know the 'consumption rates of reactants and produstion rates of products'. can u please suggest me how to get it.
thank you once again.
karthik
Old   August 3, 2001, 05:54
Jin-Wook LEE
I hope that following procedures would be helpfull to you.
Display --> Contour --> Contours of Reactions --> Rate of Reaction-1(or 2, 3...)
Report --> Volume Integral(or Surface Integral) --> Rate of Reaction-1(or 2, 3...)
Sincerely, Jinwook
Old   August 3, 2001, 14:23
karthik
Once again i thank u for ur reply. I actually want to have production rates of each and every product species and consumption rates of each and every reactants. I don't want to have overall reaction rates. take the case of methane reacting with oxygen.
CH4 + 2O2 --> CO2 + 2H2O
i want to have rate at which methane is being consumed. not the reaction rate of above reaction.
THANKS karthik
Old   August 4, 2001, 12:04
Devy
Now I am studying TUT 8.in fluent mannul, "Chemical Mixing and Gas Combustion". I don't consider the reaction of air and CH4.I just consider the reaction of pure oxygen and CH4.So I remove the N2 from material pannel.I change the air as to oxygen in the boundary of air-inlet.And I use Cp calcualated by mixing law and put the piecewise-polynomials in for each species. I don't change the other model.
When the solution is converged,I found the temperature rised to 4800K.And this is not true.Theoretical values of combustion temperature can be obtained from industry standard thermochemical codes for pure oxygen and CH4.And the temperature is about 2800K.
I've tried everything I can imagine!!!
Would you give me some advice?
Thanks a lot, in advance......
Devy 2001.8.5
Old   August 5, 2001, 18:54
Ugur
I don't know where you get the temperature of 2800 K as maximum flame temperature, but if you consider a constant volume adiabatic combustion, it can be upto 6000 K, for stoichiometric combustion.
Ugur
Segmentation fault in running alternateSteadyReactingFoam,why? NewKid OpenFOAM 18 January 20, 2011 17:55
UDF for catalyst volumetric reaction, temperature overshoot though rate is small elmcmaster FLUENT 0 October 11, 2010 10:37
surface reaction rate with udf yellow-stuff FLUENT 4 January 29, 2010 13:53
UDF changing the rate exponent of a reaction Stefan H Fluent UDF and Scheme Programming 0 September 16, 2009 14:20
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 01:07
