unable to read grid file ?
Old   July 19, 2001, 09:13
Default unable to read grid file ?
bluebird
Hello,everyone,
As a new learner of FLUENT,I need your help very much!
Today after I finish the work in prebfc 4.3 and save the grid file,I can't read it in the FLUENT correctly.The message is "unable to read grid file".
I don't know how to overcome this problem.Would you please to help me?
Thanks for your help very much!
Old   July 19, 2001, 17:07
Default Re: unable to read grid file ?
Lanre
What version of FLUENT?
Old   July 20, 2001, 01:45
BLUEBIRD
VERSION 4.3
Old   July 20, 2001, 11:17
Ropey
I'm a novice user so hope I'm not pointing out the obvious, but have had the same message before and may be able to help. I'm using a later version with gambit as the pre-processor, but in gambit you have to make sure you save and export a mesh file. After going into Fluent, you have to import it by asking it to read a case file, and then select the correct mesh file. Hope this is of some help.
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 09:48
Problem installing on Ubuntu 9.10 -> 'Cannot open : No such file or directory' mfiandor OpenFOAM Installation 2 January 25, 2010 10:50
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
[Gmsh] Compiling gmshFoam with OpenFOAM-1.5 BlGene OpenFOAM Meshing & Mesh Conversion 10 August 6, 2009 05:26
[OpenFOAM] ParaView 33 canbt open OpenFoam file hariya03 ParaView 7 September 25, 2008 18:33
