UDF for the boundary condition
Old   July 12, 2001, 14:19
Default UDF for the boundary condition
Sridhar
Dear friends,
How can we write a User defined function for the boundary condition specifying that the vertical component of velocity is zero and the temperature is T_infinity, i.e 293K in my problem. I would be very thankful if anyone can clearly give me the C-programme for writing the UDF.
Thanks.
sridhar.
Old   July 12, 2001, 21:42
Default Re: UDF for the boundary condition
Greg Perkins
Use a profile function - some examples are in the udf manual
Old   July 12, 2001, 21:43
Greg Perkins
actually do you need a udf for this??
Old   July 13, 2001, 20:18
Sridhar
Hi Greg, thanks for your responce. Do you think is there is any other way to represent the boundary conditions which I am intrested in applying?? if so please help me. Actually I am working on "bouyancy driven flow over flat vertical plate", If you want clear description of the problem, I appreciate you very much if you could please refer to the messege which I posted on June 25th with the title " natural convection flow over flat vertical plate". actually I am trying to set the above boundary conditions to the boundary which is located opposite to the vertical plate. I tried applying pressure inlet conditions to it, but I am not getting the velocity boundary layer at the wall.
I sincerly request if Anyone who is familiar with this topic can please help me. Thanks
mixed inflow/outflow downstream boundary condition question peob OpenFOAM Running, Solving & CFD 3 February 3, 2017 11:54
Resolved: Changing boundary condition with UDF according to pressure outlet boundary alpemre Fluent UDF and Scheme Programming 12 February 24, 2014 11:18
Boundary Condition Types Using Scheme and UDF Nasir FLUENT 0 September 15, 2008 22:54
UDF for boundary condition Shankar FLUENT 4 February 26, 2002 21:00
UDF : boundary condition ID Flav FLUENT 4 June 28, 2001 10:52
