Pressure contour seems wrong???
Old   June 28, 2001, 06:05
Default Pressure contour seems wrong???
Harry Qiu
Dear Mr. or Ms.:
I am simulating a turbulent flow problem with Standard k-epslon model.My problem setup are as follows: 1. velocity inlet 2. pressure outlet 3. K-Epslon turbulent model
After iteration, I find that the velocity distribution seems right. But the pressure distribution seems wrong, because where the static pressure is large, the velocity pressure is large too. So this results in the total pressure difference between different points is much bigger than I expected.
For example: the fluid flow through a sharp-expansion duct, before the sharp-expansion the total pressure is 20000 Pa, but after the expansion the total pressure is 0 Pa. I think it's a wrong iteration resolution.
But can you tell me why I get this wrong sovlement?
Thank you very much. Any points are welcomed.
Sincerely yours, Harry.
Old   June 29, 2001, 06:53
Default Re: Pressure contour seems wrong???
zhou_eric
My response has been posted on under your other question. Just go there!
Eric
How to read pressure at discrete points paka OpenFOAM 16 April 28, 2020 08:26
Correct pressure distribution but wrong aerodynamics coefficients Aerospace OpenFOAM 11 December 12, 2012 06:05
Pressure contour KK Khan Main CFD Forum 1 June 26, 2006 00:35
Displaying numbers on pressure contour Arif Saputra FLUENT 0 October 6, 2001 13:38
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
